Big Big Problem
11 replies · 2,650 views · Started 26 January 2006
Well... i changed my lock code... and i forgot it... what do i do, how can i reset it? I didn`t find anything about that in the manual...
thanx
You can't.
You would need to go to a Nokia Service Center and have your phone reflashed. This will wipe all data on the phone.
No there isn't. The reason being is it is a security code and intended to prevent stolen phones being used.
I may be wrong, but I think that a hard format can fix it. Hold 3, * and the green key while turning the phone on and don't release them until the phone finishes booting (or asks the PIN code). Try this only if you can't start the phone at all without knowing the code. If you can start it, try restoring a backup of the phone's memory. If you don't have one, just copy it from another 6630. It should be located in E:\Backup\Backup.arc. If this fails you will have to go to a nokia centre. I'm not sure this will work, It just seems to me to remember that after I restored a backup the protection coded returned 12345.
I hope this helps you.
EDIT: I tried. Restoring backup doesn't restore the code from the backup.
Well you can unlock your phones in two ways:
1 - Flash your phone with any flash box.
2 - Use restore factory settings with flash box>
goodluck:icon14:
Black Antitoon wrote:I may be wrong, but I think that a hard format can fix it. Hold 3, * and the green key while turning the phone on and don't release them until the phone finishes booting (or asks the PIN code). Try this only if you can't start the phone at all without knowing the code. If you can start it, try restoring a backup of the phone's memory.
RageOne, did this work? Do tell!
Steve
the hard format thingie didn`t work... now i`m trying to get a backup fom someone... anyone 😃
if anyone could email me a backup i would be really thankful... [my email is [email][email protected][/email]]
RageOne wrote:the hard format thingie didn`t work... now i`m trying to get a backup fom someone... anyone 😃
Sorry, I tried it on my phone, it doesn't work. What I remembered was wrong. Since my phone has just been stolen, I'm really happy that it cannot be used. The thief won't have fun, unless he can flash the firmware without going to a Nokia point.
oh, well, i`m from romania... and here stealing phones is a real business... your phone can get lost really easy... probably that`s why there are lots of "underground" guys that do flashing and unlocking :frown:
solved my problem... there`s a software called phoneunlock that resets it... if anyone really needs it, email me
there is amaster code for every mobile (10 digits) that unlock the phone without knowing It's real code (5 digits).
tell me your phone serial number and I will send you your master code ......
