serious n3230 prob
2 replies · 2,147 views · Started 27 January 2006
i have charged my n3230 last night and fell asleep and then after i wake up i just realized that i have charged my n3230 for 9hrs...then when i was about to pull the charger its not hot as instead it was cold but when i was to press the menu button on my n3230 on the upper left of the menu symbol on the botton of the menu symbol i have noticed that it was blinking..is it really normal for that phone or did the lcd of the phone was destroyed when it was over charged pls help me and the dust prob inside the phone was really annoying i can open the phone because it has a warranty.. n3230 users pls help me in hre. thank you so much!
[IMG]http://img223.imageshack.us/img223/2318/120ig.jpg" loading="lazy" alt="User posted image" class="post-image">[/IMG]
attached is the image
I think 9hrs is not a long time to charge the phone. It is more likely a normal routine to charge phone over night. I would also like to remaind you that there is much more "intelligence" in charger circuit than you might thought. There is NOT risk for over charging!
If you can not fix your phone just by rebooting it, I would advice you to contact to service.
[QUOTE=n3230grl] Hi n3230grl, it is abnormal to have the blinking at the MENU
icon. I normaly switch off the phone before carrying out battery charging.
Do close monitor of your n3230. Cheersssss.
