Hi all,
Just installed Tomtom 5.20 on my nice new 512mb card, but whenever I run Tomtom I get through the preferences to the map select which displays "No maps found". I've carefully installed everything in the right place, all my map files in the root dir Great_Britain-Map as instructed but still no joy. Can't find any help on Tomtom's site and just wondered if anyone could help?
I'm using an Orange N70, a 512mb card and have to transfer everything via BT then move it with FExplorer as I have no card reader...
Many thanks in advance 😊
u can find the files and move them to your MMC!
the files are into the folder:
/system/mail/...
u have to copy them 1 by 1!!
i suggest you to make it another way!
try to package the map-file into a SIS or a ZIP 😉
I have moved them 1 by 1 but it doesn't work, "no maps found". I'll try zipping them or makesis as you suggest, but I wondered if anyone could show me their directory structure as I assume I've messed it up somewhere...
Just a small point but my map directory is named Great-Britain-Map which is slightly different in as much you show a _ after the word Great.
might make a difference
Tried sending the files via zip and using Zipman to put them in the right place, and I renamed the map folder but no use, "no maps found". Planning to invade my Dad's PC tomorrow and make use of his card reader...
