Sound problem ...
11 replies · 2,265 views · Started 19 November 2002
Just a question to all 7650 owners.
Do you have the same buzzing noise when you call someone or you get called ?
It's the humming noise you hear on a radio if you stand to close. I think my 7650 is disturbing itself ... bad shielding.
Anyone the same problem ? Solutions ?
I have software version 3.16 not that it makes a difference 😉
jap, have the same prob :cry:
pretty bad sound when im on the phone, but you will get used to it 😊
you probably will have to unless it is fixed in the next fw
[quote="JyriK"]Is this it?[/quote]
no, its more like a humming noise in the background everytime i make or get a call.. u can phone very well, the sound gets anoying after a while..
it sounds like te phones in the very beginning (i suppose they sounded like this!).. like a bad connecting..
greetings from d�sseldorf, tias
I dont have the humming sound, but i do get a slight interference, as when it happens when u are near computers when u get a call. Only.. to me it happens even outdoors.
This is rather more pronounced at the start of a call, and then it fades out.. (or i dont notice anymore)
Yeah i know what sound you're talking about, It happens everytime.
I'm pretty sure i read this before, the cause of the sound in the 7650 is interfierence between the phone's LEDs and the phone itself, so when the phone's LEDs go off (after a couple of seconds) you don't hear the sound anymore.
Thanks for the "science" behind my buzzing problem ..
Now I have a terifying dillema 😉
Should I demolish the leds 😮 or learn to live with the bzzz ...
:cry:
Whaaaaaaaaaaai (Why in Dutch/English 😉)
It's the idea that counts 😊 ('t est idee da telt huh .. nen vloaming hie)
I'm very much into soundfx ... Whaaaaaaai klinkt lekker 😉
