Hi does anybody know how to view videos in widescreen on my Nokia 3230 or do I need a program to do this or is it not possible. Also does anyone know how to change the covers as Ihave found two screws but cannot find the rest. Thanks EDGE
widescreen
samedge@tiscali wrote:Hi does anybody know how to view videos in widescreen on my Nokia 3230 or do I need a program to do this or is it not possible. Also does anyone know how to change the covers as Ihave found two screws but cannot find the rest. Thanks EDGE
regarding to your first question....
try to use mobile theater... its more wider and larger compare to real one player...
second question...
yes! theres 2 screws at the lower back of 3230.. the other 2 screws are in the upper back... u must removed the upper cover of your 3230 housing.:icon14:
dont hesitate to PM me just incase you still have questions....
For full screen viewing you can use Cristal Player for mobiles or PVPlayer. 😃
On most recent S60 devices, pressing '2' toggles full-screen playback on and off. I'm not sure this applies to the 3230 though, which has an old version of Series 60....
Steve
