Remove Orange Software
3 replies · 3,716 views · Started 31 January 2006
Does anyone know if it is possible to remove the Orange software from a 6600 and if there is how do I go about doing it. Thanks :con?
scottbryant1975 wrote:Does anyone know if it is possible to remove the Orange software from a 6600 and if there is how do I go about doing it. Thanks :con?
hey good news. at last i got rid of the shitty orange software from my N70. all you have to do is Flash the phone. many people were saying that it has got some side affects on the phone. but my phone is working fine. the only thing is that it is a risk with all the memory and contacts that you have got on the phone. they might go off after the flash. mine one didnt but my friends did. but not a problem. if you go to settings on the phone and then to memory and the go to the options , it says over there. back up all phone memory to the memory card. then remove the memory card and then flash the phone. if your memory is lost you can recover it. my phone is working so fast now. you wouldnt believe it.
