Q. Having bought a new Nokia smartphone, I'm having problems installing most of the programs I've downloaded. The error message is 'Installation security error, unable to install'. I spoke to Nokia and they say there is no security feature to prevent software installation.
Hi all,
I am trying to get my new N95 working with DataViz RoadSync (with MS Exchange 2003 SP2), which appears to be working great - with the following caveat:
I can't find a way to install a self-signed certificate (created by MS Small Business Server 2003) to prevent the annoying cert prompt when it synchs.
I have followed a few posts, but to dead ends.
When I try to install an exported .cer file (by Bluetooth transfer or using File Explorer), I get a 'file type not supported' error. Similarly response with a .p7b file.
Can you assist or advise in how I might fix this?
Many thanks,
Patrick Nash.
