Hi!
After installing eExtras, when I create new folders, can I remove the original folder "eExtras" without problems?
Regards
Hi!
Regards
Mano😉 ,
No, u cannot as this is the app itself, not a folder. I deleted eExtras compeletely to see how the folders would react but it all gets a little buggy then, so est to keep it there.
regards,
Jan
Ok! Thanks, Jan! ![]()
You can rename the eExtras folder....and then work this as normal folder...![]()
