Ok, I bought my 6260 a couple of days ago, and today it arrived in the mail. Anyhow, in the manual it says that I should just press lightly upon the mmc holder to open it, but I have pressed and pressed anywhere on the holder, and around it, nothing happens. This is most likley just me being a pretty stupid when it comes to these things, but nevertheless I would appreciate some help.
Problem with mmc holder
You don't 'open' it as such... it clips onto the bottom of the RS-MMC so make it the size of a full MMC... you just need to press on it a bit to allow the corners of the card to clip into the holder... if you get me...
Ok, Ive found out what to do. Seems my Norwegian manual was pretty far off, looks like I was supposed to pull instead of push. Thanks anyway. So just let this one fall...
