I currently own both a 6680 and a N70. It seems that Nokia have dropped the wallet feature which I found very handy on the 6680, and not included this in the N70.
Can anybody recommend a 3rd party app as a replacement?
OR; Does anybody know what files I need to pull of my 6680, and if it will even be feasible to transfer the wallet from the 6680 to the N70?
z:\system\apps\(now find the wallet app,you mite have to go through all the folders just opneing the .apps to find it)
send the whole folder contents over to your n70 then create a folder in eitha c:\system\apps or e:\system\apps & call it wallet then place all the files that were in the 6680 folder in this new folder
btw youyll need a file managing software, eg fexlporer
Won't help. Files from the Z-drive will not run from any other drive in the same or another phone. Look into products like Handy Safe, or comparable, instead.
you sure there were files on my 6630 that i put on my n70 that work perfectly
Thanks!
I'll give it a try over the weekend, and post back my findings.
I'll also look into Handy Safe, while I'm at it.
I also missed this feature so downloaded Handy Safe. It works fine although the Windows app that you use to back it up to PC doesnt (or didnt) support the N70. When I emailed the support they said they would be releasing a new version of that around the end of Jan that would support the N70, but I havent yet checked on their site to see if its updated or not.
