i just bought my n70 yesterday. after installing some applications, the phone is unable to start now. it just gets stuck at the nokia screen. what can i do? thanks
need help!
Here you go...this is another discussion on resetting N70
http://www.allaboutsymbian.com/forum//forum/thread/43318/&highlight=reset+hard
Gtroc
i get the same with installing a certain app
its due to the memory card, best way to fix it is to take it out, then put it back in when you're in the menu and then format the card
