Hi all:
I want to Buy a Bluetooth card for using in my PC with the Emulator of Series 60 SDK. Now I wanna know which card is compatible with 7650 and can be used with the SDK Emulator? IS SOcket card theonly one? Is there any other cheaper solution?
Hi all:
lots of people using the MSI transcieving key (USB port)
also it's cheap around $40- $50
Where to get it ? And does it work with the Emulator of Series 60 SDK?
maybe a u can buy in a computer store near you
btw why u want to use bluetooth with emulator SDK 60
are there any connection between these two ???
