the MCODE program code didnt work
i have a nokia 6680
IMEI: 355664000058333
i've forgot th lock code
can u send me the master code plz
HELP: nokia 6680 lock code problem
your master code is (7153557243)
With the MC, use only 5 digit. Start with the 1st digit. So, in this problem, ur MC it should be 71535
Hi all, i have missed my lock code (i renewed it from the default 12345), and i used the MCode app to find the master code, but when i get the first 5 digits to unlock my phone, it does not work😡 :con? . Can you guys help me to reset or find my lock code.
Thank you very much!
What is ur phone model? AFAIK, first '5 digits' only for Nokia 6680 and if all number (generated from MC - 10 number) won't work then I think ur phone is a member of BB5 phones and there's nothing u can do about it. U must take ur phone to nearest NSC (Nokia Service Centre).
For more info,
The Calculator can dct 3 and 4, and these are the phones:
DCT 3: 2100, 3210, 3210A, 3310, 3315, 3320, 3330, 3350, 3390, 3390B, 3395, 3410, 3610, 5110, 5110i, 5110iA, 5120, 5125, 5130, 5160, 5170, 5180, 5185, 5190, 5210, 5510, 6080, 6081, 6090, 6110, 6120, 6130, 6138, 6150, 6160, 6161, 6162, 6185, 6188, 6190, 6210, 6250, 7110, 7160, 7190, 8210, 8250, 8260, 8265, 8270, 8290, 8810, 8850, 8855, 8860, 8890, 9110, 9110i
DCT 4: 1100, 1100B, 1108, 1110, 1600, 2220, 2260, 2270, 2272, 2275, 2280, 2280A, 2280B, 2285, 2300, 2600, 2600cn, 2650, 2651, 3100, 3100B, 3105, 3108, 3120, 3120B, 3125, 3200, 3200B, 3205, 3220, 3230, 3300, 3300B, 3360, 3510, 3510i, 3530, 3560, 3585, 3590, 3600, 3620, 3650, 3660, 5100, 5100A, 5140, 5140B, 5140i, 6020, 6020b, 6021, 6030, 6060, 6100, 6101, 6102, 6108, 6111, 6170, 6200, 6220, 6225, 6230, 6230B, 6230i, 6255, 6260, 6260B, 6270, 6280, 6310, 6310i, 6340, 6340i, 6360, 6370, 6500, 6510, 6560, 6590, 6590i, 6600, 6610, 6610i, 6620, 6650, 6651, 6670, 6670B, 6800, 6800A, 6810, 6820, 6820B, 6820i, 6822, 6822B, 6830, 7200, 7200B, 7210, 7250, 7250i, 7260, 7270, 7270B, 7280, 7600, 7610B, 7620, 7650, 7700, 7710, 8310, 8390, 8800, 8801, 8910, 8910i, 9300, 9300B, 9500, 9500B, N-Gage, N-Gage QD
Oh God, really?😮
So, do you know where to download the Symbyan OS in order to set up the phone N6681??? I want to reinstall the operator system.
Thank you!
U don't need to reinstall the OS in case to get back the lock code. At the moment, only Nokia can unlock BB5 phone.
If u want to reinstall the Symbian OS on ur phone, it's a hard job. U must have legal firmware, expensive tools and a good brain. Just take ur phone to nearest NSC (Nokia Service Centre) and let them reinstall it 4u or local reinstall (flashing).
Hello All,
Please help me. I got a 6680 and somehow managed to lock it and I don't know how to get it unlocked. I've tried 12345 but no help. I got it second hand so i guess i am screwed now. I have no idea how to get the IMEI number. The info under the battery is as follows:
Type: RM-36 Model: 6680
355664/00/003857/4
Code: 0523641
FCC ID: PDNRM-36
IC: 661R-RM36
PLEASE HELP :con?
To get ur IMEI, type
*#06#
BTW:
If the 1st 5 digits won't work, then only Nokia or nearest NSC (Nokia Service Centre) can help u.
Ok, this is my first post here, but google sent me to your site, so I hope you can help.
I made a mistake by trusting a bad seller overseas on eBay and purchased a used 6680. The phone was advertised as unlocked, with all the extras.
Today I got a locked 6680 with nothing, no cables, no chargers, no nothing. I did not even know where to start or how to get the IMEI. 😡
Your forum gave me that info, thanks very much :icon14:
The IMEI is 357062004163258
Can I ever use this phone, if so how.. can it be unlocked or do I have a $200 silver paper weight?
Thanks so much..
Craig S.
Dear All
HOw are all you I don't know if some one can help me I need urgent help.
I forgot my mobile code its Nokia 6680 and the IMEI is 355661007450851
So help me as soon as possible.
Thank all you
hi i have a nokia 6680
as i start the phone it asks for a lock code .. how do i get round this because im not sure what it is !!
my IMEI:357617/00/852071/0
any help please
i have a nokia 6600
IMEI:359365005525955
:redface: :con? :con?
try this guys
[QUOTE=XecutioneR]the PHONECODE program code didnt work
i have a nokia 6681
IMEI: 355660006538757
can u send me the master code plz ON MY E-MAIL ADD ([email protected]
i have a nokia 6630
IMEI: 359733004209170 or 3597334209170
can u send me the lock code idol😞
ryzen17 wrote:the MCODE program code didnt work
i have a nokia 6630
try the UNLOCK program i've posted!! 110% wrking and u will get your security code!!! the mcode works for all phones and not for bb5 phones(from my experience)!!!
Wirelessly posted (Nokia6630/1.0 (5.03.08) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)
355664000058333
i have a nokia 6630
are ppl on this thread dumb or is it that only dumb ppl phone that gets locked!!!! download the UNLOCK ME program i posted and that will unlock ur phone!! and stop asking stupid question or giving your IMEI code!!
hi need help bougt 2 hand nokia 6680 and its not unlocked plese help
IME# 357062003274015
hi this is my first post. i am a new member. can u please help me. i have n-gage QD. i was using it back in india. but now i wan to use it in USA. the problem is it doesnt shows the network in USA. is there a mobile lock problem? can u please help. my mobile IMEI is 353360000929936. also tell me how to unlock it. thanks in advance.
this actualy works
I have a nokia 6680 and the same problem.
IMEI: 35661001541655
code: 0521698
I've forgot the lock code.
can u please send me the master code?
heyy can some one pls send me the phone system lock code... I have put tat code on but forgot wat it was soo pls I need it asap because I need to use it thnx allooottt the imei is :353755/00/160126/1 thnx alot man I need asapp
oh and the cell is a nokia 6620
hi, I need your help. Today I've received a 2 hand nokia 6680. But I don't know the lock code. :con?
Can you people send me the master code, plz?
Help me plz
IMEI: 357617000576470
Please can someone help with the MC for my nokia 6120 Classic.
IMEI: 355664001723125
need the master code .plz! phone is freezing. need master code to reset phone.
I'm was playing with my phone too and i changed the security code, i enter the code 987654, the phone acepted the code, but when i tried to unlock it doesn't work, but i discover that the phone only record the first 5 digit, then my code is 98765, try only the fists 5 digit of your new code, bye
i have a problem with a NOKIA 6680 may mobile restarts every 3 minutes...... I can't do anything with pressing three keys and power button..... my ime is
I forgot my code :
357062/00/618792/5
HELP quickly please
