I have an N70 and a G5 iMac. I've managed to get iSync to work by using the Nova Media plug-in for contacts etc, but is there a way I can transfer the entire contents of my phone's gallery to the iMac without Bluetoothing every picture independently?
The phone isn't recognised at all via the USB connection.
I also haven't been able to browse the phone via Bluetooth with the iMac - should I be able to?
Thanks in advance.
You could use an USB card reader and plug it in the Mac and put the memory card from the phone in the reader. Fastest and most efficient way to copy/move the pictures.
There is no USB driver for the Mac for the Nokia USB cables (DKU-2, CA-53), so you can't use the cables for that. That problem will be solved with phone models that have, so called, USB mass storage class support built-in (won't help you with the N70, though, I'm afraid).
