Connecting via Bluetooth
9 replies · 2,772 views · Started 20 November 2002
I just thought Id give it a try and managed to send a Image via Bluetooth to my mates Sony T68i...
....worked a treat ..
😃 one thing I noticed when bluetooth detects the phone and you click on it on the menu - it asks for a passcode?
Anyone got any idea how you set this ? or is this for other devices ? :roll:
The Bluetooth device will be able to detect all other Buetooth devices within its range. Therefore, when you are going to commnicate between two BT device. You need to pair it first. By mean of pairing, it will ask for pass code. You just given any number and have to be the same at both sides.
is there a way to send picutre from 7650 to my PC via bluetooth? i have MSI bluetooth on my PC. :roll: :roll:
You can send pictures from NOKIA 7650 to PC by using PC suite which is given with the 7650, and vice vesa. You can also use SeleQ to do it for you.
F1gpshop..There're some comprehensive procedures detailed in posts here, in making the Bluetooth work. Make a search, you will find it. Beleive me!!
Goodluck 😃
hope so. 😉 thanks!!
anyway, i can receive files from my PC to my 7650 via BT, but not vice versa. 😞
Yeah f1gshop.. this is a common problem. But only needs a minor fix. I'd have explained it here..but its been explained too many times erlier, and also..its rather long to type all over again.
Infact..you should be able to find it in recent posts, also, its listen in FAQs. You will find it very helpful
PS: If u have a problem inspite of that, pl feel free to let us know. We'll do our best 😊
