Copyright Protected - Cant send certain files via bluetooth
5 replies · 15,034 views · Started 09 February 2006
hello to all that read this - would really like some input...
I cannot at the moment with file exploring programs such as FExplorer and i've tried a few others as well.... when i try and send a .sis or .jar/.jad (install files) it comes up with "Unable to send copyright protected item". I have no idea what to do - any help???
Cheers Neil.😊
Rename the file (change .sis to .xxx or whatever). On the receiving side there must be capability to change the name back, if the receiving device can't handle it otherwise.
download ProfiMail - along with it you get the ProfiExplorer file manager, using which you can send such items. If you can not send protected items even with ProfiExplorer you will have to do what BarraSpalding said (you can use ProfiExplorer to rename files since FExplorer does not have this option)
wtf, what version of FExplorer do you have?? You can set even attributes for files, not only rename them. Version 1.16 (beta) allows to rename only by pressing 8 on the keypad.
i have a software Profimail i will send it to u later.
With the help of this software u send protected items..
send me ur email adress so i will send it to u....
Songs songs are Copyright Protected so you can't actually send those to the phone, download them from another source and then try sending them on to the phone and that will work
