On my wife's 5140i the "Go to"-menu allows you to add shortcuts to profiles, applications, settings, etc. On my N70 however, all I'm able to add, besides the default Calendar, Contacts and Inbox shortcuts, are pictures and sounds.
Is it supposed to be this way?
yes unfortunatly. some how nokia have changed they way favortites or go to items can be added to s60 2.2. used to be that you could use an app like appman from symbianware & add favorites cant do it now crashes the go to menu
you can't even delete items on you go to screen... but what I did was moved the files about vodafone commercial bullshit to below, so you can't see it unless you go down offcourse.
