I learned that there is a low definition display mode for power saving, but I searched the entire user manual and was unable to find the way to turn it on. anyone knows?
thanks.
thanks.
That "partial display mode" is nothing but the screensaver which shows the date, time, network operator name,profile applied,which line you've selected(Line1 or Line2),and some extras (if applicable) like if the bluetooth is on or not,etc..That is the "Partial Display Mode" dude..
onlybobby wrote:That "partial display mode" is nothing but the screensaver which shows the date, time, network operator name,profile applied,which line you've selected(Line1 or Line2),and some extras (if applicable) like if the bluetooth is on or not,etc..That is the "Partial Display Mode" dude..
thanks a lot!!! you solved a big mystery and bs.
tomlu01 wrote:thanks a lot!!! you solved a big mystery and bs.
You are welcome brother...
how i get the "partial display mode"
in my menu....
sory i early in 7710....
i was migrated from NGAGE
