GPRS connection
2 replies · 1,775 views · Started 09 February 2006
I installed Google local, Opera Mini on my 7710, but everytime they try to connect to web there is problem, but I can use default brower to surf, anyone knows the solution.
thanks
Hi Tom,
I just swicth from Cingular to Tmobile, and sign up for T-zone, The Web access work better and cost less, but some time I run in little problem with url site with Java plugin (Java enable selected on 7710) some how it doesn't launch the applet and does Google local use Java? try this URL to test your internet speed. http://myspeed.visualware.com/, let me know if you have same problem.
Eric.
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 5.0; Series90/1.1 Nokia7710/3.04.2 Profile/MIDP-2.0 Configuration/CLDC-1.0) UP.Link/6.3.0.0.0)
enguyen wrote:Hi Tom,
Eric.
if you use access over apn wap it posible becouse your operator maybe lock proxy or dont support tcp/ip protocol.use the apn internet
