Hi, i have the N6680. The back door that should enable the camera doesn't work. I open the door and nothing happens. Also when i switch to video recording an error says "feature not supported" and i can't record anything. It's something wrong with the software. Do you have any solution...?
i would really appreciate if you help me
Do things work if you take out the memory card? If so, then it has gone bad somehow.
If that's not enough, then reformatting the phone might help: http://www.allaboutsymbian.com/forum//forum/thread/17507/
If not, find your nearest Nokia service/repair center: http://www.nokia.com/repair
does the front camera work. if so go t options and activate the rear camera.
bye
N/A wrote:Do things work if you take out the memory card? If so, then it has gone bad somehow.If that's not enough, then reformatting the phone might help: http://www.allaboutsymbian.com/forum//forum/thread/17507/
I am sorry for righting in greek.. Anyway the problem still goes on and on, when i try to record video--->"feature not supported" :con?
Cotsios_89 wrote:Nai file m, omws i diadikasia gia format den petyxe sto 6680... Mallon to problima einai me ta 3gp's giati kai stin gallery giati tin e3odo apo anaparagwgi video so 3gp format argei to kinito. k episis otan 8elw na kanw video recording m grafei "feature not supported" :con?
If you say so. I have to take your word for it. 😉
hey dude....even i have the same problem......when i slide the backcover...the thing just gets stuck.....i have to use taskspy to kill the camera app...then the camera starts working.....YA sumtimes it tells "Feature not supported too".....I am taking my phone to a service centre soon....Pls do tell me wat u did to fix ur phone.....
ok MY friend.. I think i tried everything i could do myself, and its time to take it to the experts.. HOPE it will become new again
The problem occurs after installing some of the N-Gage games.
The cure is the following:
1 - delete e:\system\libs\ecom.dll
2 - restart the phone.
Thats's all.
PS visit Moscow and gain knowledge.
