MASSIVE N-gage qd problem! If U can solve this U R the best!
13 replies · 3,897 views · Started 12 February 2006
This thread included a poll: How did u like the problem?
Hi, i was transfering some images thru bluetooth and i forgot to turn off the bluetooth feature,later when i came home---> okay this is the problem
:icon2: When i press menu its says->Menu system error
:icon2: when i start the messages ""->Messages system eror
:icon2: when i start contacts it said->contacts system error
i tried to restart the mobile,it didnt help,also there are crucially imp contacts on ma cell,LATER
:icon2: the mobile phone started resarting automatically
:icon2: and now it doesnt start!!!!!!!
plz help...i dont mind if i'll have to format it..i just want it to be right!!!!!
Shanky 😊
shanky_ngage wrote:Hi, i was transfering some images thru bluetooth and i forgot to turn off the bluetooth feature,later when i came home---> okay this is the problem
Shanky 😊
u have a virus:icon4:
format your fone and try updating the firmware😉
anywayz all about symbian forums r crap!!
go to http://www.mobilesmania.com:icon14: :icon14: ==much better forums
Hmm... What do you mean the phone doesnt start?
1# No "NOKIA" at start. BAD luck. Firmware reboot! ( If you got warrianty, go to nokia care centre and say that the memory is too full.If you are out of warrianty, go to nokia care center anyways. just say at beginning that you want to update to the new firmware (Might get free!) (I paid 25$ for my format+firmware+rubber ring))
2# "NOKIA" comes but it is too buggy or the menu doesnt open. Try to restart the cellphone by pressing the "pen" key all the time until it is ready (I THINK it should not open any apps, i dont know about n-gage, but older symbians can be used like this.)
ive experience that before in my NGAGE QD.... gladly i had a back-up files of my NGAGE in my MEMOry CARD... when i try i use the back-up... everything will be back to normal....
i guess you must back up your phone in your memory card...
yeh i got a problm too. My phone suddenly wont let me send sms's if i try typing a msg it starts showing the numbers on the screen and not the Alphabets. wats this due to ?? and even in call logs when i chaeck for missed calls then alwasy registerd 30-40 mins earlier. if i got a missed call at 11pm it ill show 10.30pm odd !!
plz help
hi. i've an n-gage QD which i bought last year. well, recently i've this "general error" problem with the phone. when my friend send me any movie clips (.3gp) file via bluetooth, after the transfer is done, i can't open the file. it returns "General Error 0x80040016". What actually is that?? can someone pls explain to me, and also tell me what to do to solve this problem? please..and thanks. 😊
i have this game but it is not at same format before it hav a 6343 and libs folder name where should i put this two folder in order to work.... i have tried to put it all to the system folder then apps folder in my mmc but when i power up the phone it did not find any new games installed your help is very much appreciated thanks in advance
The 6343 folder goes to your MMC's System/Apps/
and you will find a folder named libs in your MMC under System . Put all da libs u have in there...reboot the cell.
I am an ngage qd user. I've encoutered that problem after few months of buying the phone. The error is very serious but the solution is very simple. To tell you honestly, that can't be fixed with a simple on/off.
Heres the solution:
Do you have celphone shops along your place?
If you have, ask them to "FLASH" your phone. Flash is like a reformat. By flashing your phone, your whole device will become fresh again(new). Believe me it worked! It's not a joke.
Wirelessly posted (NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Shanky 😊
Just format ur qd
LOL! :lol: i'v got this prob too... i formated C drive in n-gage... and it's all right... 😎
its a virus called comm warrior, it crapped up ur phone. it has happened to my phone once. just contact nokia services.
