speed up your s60 fone!
5 replies · 3,094 views · Started 12 February 2006
A method to speed up Nokia 6600
Please follow procedure carefully as in doc
and remember USE AT OWN RISK!
Im not responsable for any damage done to your phn as its safe and tested on the nokia 6600 only.
It might work on other phones but im not going to try on my n7610 1st.
MayB sum1 else pluck up some courage and try...
If u really want the stats then use a prog called spmark04 before and after to see difference in speed
Plz update comments so I can let my friend know of phone compatibilty...
Attachments: speedupn6600.doc (70 KB)
works for nokia3230.
but how do i revert back to the orginal settings?
can i delete the 2 to do notes after it?
It's an April Fools joke, its silly to think its going to speed up your phone. Its surprising how gullible people can be, you could tell them jumping up and down on one foot would speed up their phone and they'd do it!
If you want the benefit this joke supposedly gives you, just reboot your phone. I think your phone is fastest just after a reboot, which is what this joke takes advantage of.
SeanCF wrote:It's an April Fools joke, its silly to think its going to speed up your phone. Its surprising how gullible people can be, you could tell them jumping up and down on one foot would speed up their phone and they'd do it!
wtf it works
its to do with the amount of days u keep ur log for dumbass
So tell me how this affects your log?? This is a JOKE that DOES NOT WORK. Your phone may speed up slightly by adjusting your log settings, but this DOES NOT DO THAT. If you want to change your log settings, go into LOG > menu > Settings.
