Hi guys i was testing out some new fonts for my N70 and then i didnt find any that i liked, so i tried to use font remover to get rid of it but nothing happened! I was left with the font that i have uploaded to my phone. Is there any way of getting back to the old font?? Thanks
Restoring original font
for font remover to work you have to have put the font in the c drive off the phone(phone memory)
seams like you havent but heres how to do it any way
find the font folder in your phone should be e:\system\fonts
then change the name of the folder to something else e.g. font, new folder etc..
then restart phone
Yea thanks mate thats sorted the problem out - just outa interest that folder name that i changed - does it only contain new fonts that i have downloaded or does it also have the original? and i dont know if this makes a difference but the folder was in C:\system\fonts. Does it make a difference??
Cheers
the original font is somewhere in the z drive i think. but yeah only fonts you downloaded cus you made that folder when you installed the font to your phone.phone can work without that folder
