Panorama photo!
18 replies · 3,227 views · Started 20 November 2002
It's also possible to take panorama photo's with 'Photographer' from nokia http://www.softwaremarket.nokia.com/DRHM/servlet/ControllerServlet?Action=DisplayProductDetailsPage&SiteID=nokia&Locale=fi_FI&productID=583300
You have to take 16 photo's for a panorama shot, i dont see an option to lower that.. Also the pics are in low resolution for what I see.
well im using this instead of the normal capture software. It also has a built in option to change or disable the camera snapsound.
Also you can add you homemade 'masks' for funny pictures..
I like it ..and recommend it.. (still expensive though...)
really nice! pity there isnt any trial. wouldn't any body would like to try any app first before purchasing? i mean i would have never bought seleQ if i didn't have the chance to try it first. 😞
These are the kind of masks you get with this proggy.
It's also very easy to make your own...as many as you would like.
Guys,
there IS a trial of the program
It's on Handago and it works perfectly!
Check it!
http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=X7239F7BF525538E6XX6E2C31C8BB887&catalog=0&sectionId=0&productType=2&platformId=4&productId=48331
[quote="7650!"]Guys,
Check it!
http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=X7239F7BF525538E6XX6E2C31C8BB887&catalog=0�ionId=0&productType=2&platformId=4&productId=48331[/quote]
dang it!!! that's really nice! thanks for the update!!!
[quote="Cassius"]Photographer is a great piece of software. I especially like the panorama feature.[/quote]
There is no fucking try for download
//Coolaf
Dont know what i missed, but i can't find the trial on handango.
Link removed?
would someone be so kind and send me a copy of the "trial" if he got one?
plz
thx in advance
[email protected]
[quote="Anonymous"][quote="Cassius"]Photographer is a great piece of software. I especially like the panorama feature.[/quote]
//Coolaf[/quote]
Dude.... chill! No trial... no worries! Although it would be handy to be able to try before you buy - the amount of possible customers would just jump up if they offered a trial.
[quote="Anonymous"][quote="Anonymous"][quote="Cassius"]Photographer is a great piece of software. I especially like the panorama feature.[/quote]
//Coolaf[/quote]
Dude.... chill! No trial... no worries! Although it would be handy to be able to try before you buy - the amount of possible customers would just jump up if they offered a trial.[/quote]
Been posting as guest again all morning... 😞 I really must remember not to delete my cookie for this site!
