im building N70 housing using quality sheet metal, by cutting and folding it.
basically i'll remove the n70 original housing, the sheet metal is 4mm also has "suspension" in case the phone is dropped in between the sheet metal and the actual "internal phone hardware" little springs and self stick soft pads.
I just need to know, on the original cover, what material is the 3 gold/bronze pins for the battery made of ?
Basically the N70 will have a new look, like the new sony ericsson M600, without the big sliding cover, the big thick plastic cover, curved cornes, and silver/metalic look,
the only problem is I also need a front sheet of glass/plastic to cover the main screen to protect it from damage. I've not done that yet,
