Get the best out of ur 1.3 mpixel cam..
1 replies · 2,481 views · Started 13 February 2006
If ure discontent abt the quality of phone's camera......heres how to get the best out of it....
You might have noticed that the pictures taken in mobile cams get really disgusting once u zoom them on ur pc.....and mobile cam pics also have noise problem (Those multicoloured dots all over the photo)
Get this software PhotoAcute Studio....(www.photoacute.com).... u dont need the mobile version of this software if own 6630, 668x or any mobile wich supports sequence mode in camera....
Start sequence mode and take a photo.....transfer all the 6 photos to ur comp and open them in photoacute....also..check the "Fix color fringing" option in the settings of PHotoAcute studio.....check all the photos you have added and start the process.......At the end(after abt 1.5 minute) you get an amazing photo....with amazingly high resolution(as much as 5 megapixels) ....zoom in the photo and see the difference....
Sumtimes the program weirdly crops ur image..in that case uncheck the crop image option in settings..
Unfortunately u cant press save since its only a trial version....if you have 20$ spare please dont forget to buy this app....one of the best in photo enhancing...i have tried many apps...ACDSee...Adobe...Mobile Photo Enhancer...but this is the best.....
But for people like me who don have 20$ to spare....what is "Print screen" on ur keyboard used for? 😃.......set the view size to 33%...press print screen...goto paint or any other app.....crop the photo out of ur screen image....and save it as bitmap....convert this bitmap to jpeg using any photo editor but dont forget to increase the resolution before exporting(to sumthing like 1600x1200 or more)....
and there you are.....with an amazingly high quality photo....ppl wont know whther u have taken the pic with a 6680 or a digicam..
I have attached 2 pics to see how powerful PhotoAcute is....The first image is the one taken from my 6680 with normal mode and full zoom (6x)...the second image is corrected by PhotoAcute...
Attachments: kbrd.jpg kbrdcorrected.jpg
glenndanthi wrote:If ure discontent abt the quality of phone's camera......heres how to get the best out of it....
That's great, but how often do you have the chance to take 6 sequential photos of a subject that's not moving, in actual use?
