:con? Hi,
I need some guidence on how to include some classes from one SDK into another.
JSR-179 isn't available to the motorola A1k SDK but some nice chap here http://forum.mgmaps.com/viewtopic.php?t=14&sid=ef139fec5879dbb5f10db263d02f9d9e found out that the Java API could be found in the A925 SDK! I downloaded it and YES there it is exactly as described.
Being a Java n00bi I have no idea how to use these APIs into the JavaBean WTK SDK. If I can solve this problem (guys? gals?) then I thought a good experiment would be to recompile FindThePlace from http://per.nitro.dk to work on my A1k. This little app is simple but also uses the henson.midp.float class, which AGAIN I have no idea how to use in the java code.
Any guidence you can give would be g8.
TIA
Sean
