I've got a 6630 with Three. I've got international roaming but when abroad I can't connect to a local network. I called Three CS who said to check if I can get Network Selection in the Tools/Settings menu. I can't. They said I needed a software flash/flush. I did this at Carphone Warehouse but this has not made a difference. A pal has the same phone on Three and the network selection comes up fine. So is this a software problem or something earthier? Thanks for any help!
Nokia 6630 Network Selection problem
I think so 😊
BTW,
Here is the log:
Changes/improvements e from MCU SW v 3.45.11.3 to v 4.03.18:
Telephony:
- 2-digit voice mailbox numbers supported (e.g. “*30”😉, earlier minimum was 3 or more numbers
- GSM AMR voice codec supported
- Behaviour improved when Call Control and FDN is activated
- Operator name display functionality improved
SIM / USAT:
- USAT Mobile originated Short Message Control supported
- USAT Send DTMF supported
- Terminal now responds also to unsupported SIM ATK commands to ensure running toolkit application can continue running allthough some spesific commands would not be supported
- Handling of SIM phonebook with additional numbers (ANR) improved.
- Handling of long SIM ADN contacts (up to maximum 30 numbers) improved
- Terminal can better handle USIM phonebooks with differing sizes of ADN blocks
- Interoperability with specific RAN infrastructure improved
- Phone behaviour improved when performing ISHO
- Phone behaviour improved in weak field conditions when performing a blind handover from WCDMA to GSM
Audio and Video:
- Wider UDP and bandwidth ranges available in phone variant SW
- Streaming rate adaptation supported
- Interoperability improved for some servers
- Identification and playback of some streaming files identified to be 3GPP rel6 format now possible (please note that Nokia 6630 does not support all 3GPP rel6 streaming requirements)
- Resuming of streaming after MT call improved
- Up to 2MB DRM protected files can now be set as ringing tones
- Handling of pause and play with long MP3 variable bit rate files improved
- Ringing tone playback improved in low memory situations
Browser:
- Handling of content with multiple nested object tags improved
- Handling of underlined links improved, link visibility now better for end user
- Handling of saved browser pages with inconsistent HTTP content-type header and actual encoded content text type improved
- Browser memory handling improved.
- Decoding of HTML tag information when split between different TCP packets improved
- HTTP pipelining will be set as disabled in terminal to ensure correct display of images and other content when used with spesific content servers (IIS 4.0, 5.0 and Netscape-Enterprise 3)
- Cookie handling on some webpages improved. ECMAScript handling changed.
- Handling of white space encoding for plug-ins changed, browser no longer closes itself
- Table rendering improved
Video Call:
- Video Telephony DTMF tones supported (UII messages)
- Bluetooth headset supported during VT call
- Further improvements on video call setup time implemented
- Some localisation texts updated
- Automatic access point settings updated
- PC Dialup over USB improved
- Bluetooth headset connection swapping between headset and mobile improved
- Symbian installation trust setting for Geotrust CA for UTI used for verifying signing of midlets now set to “untrusted” instead of trusted.
- Java Audio playback improved
- MMS handling improved
- Global GCF 3G WDCMA Certification
- UI:
- Incoming Calling Line Identification (CLI) shows in addition to matched name also phone number
- Manual network mode selection is possible via settings. Default setting is “dual mode”, user may select “GSM only” if needed
- PDP disconnect dialog is shown to user if the network cannot give an additional data context when streaming is launched from a browser page
- Partial Idle screen indicates unread messages indicator
- Manual network selection list has been made shorter. Only one operator name is shown in the list even if operator has both 2G and 3G networks available
- Telephony:
- Dialling to prefixed numbers (e.g. *140”number) improved
- USSD session ending handling improved
- Alternative Line Service (ALS) improved
- SIM:
- Reading language information from SIM improved
- SIM handling improved for large phonebook
- Some changes to USAT commands “Play tone” and “Refresh”
- Audio and Video:
- Ringing tone behaviour improved
- Streaming improved to work better with some servers
- Memory handling improved when playing audio or mp4 content
- Browser:
- Large File download behaviour improved
- Handling of web sites sending incorrect content types improved
- Video Call:
- Interoperability improvement, Vendor ID now sent in H.324 information
- Help application help texts updated
- IMEISV sent to network changed to 17
- Manufacturing process improvement due to optimised power management software
- Always online email behaviour improved
Firmwarechanges between 4.03.38 und 5.03.08 --> 6630
Nokia Mobile Phones Service Bulletin No.
SB-023/07.10.05
Telephony
* FDN phonebook stability improvements.
* DTMF play speed corrected.
* Improvements to incoming call handling when playing games.
* CLI shown now correctly after a fax call.
* Improvements to automatic redialling.
* Correction for reset problem when receiving forwarded call from switchboard.
SIM / USAT
* When changing active code from PIN to UPIN, UPIN is asked, too.
* SAT Play tone volume increased.
* Phonebook’s thumbnail images shown when scrolling.
* Service provider name shown correctly when SPDI read from USIM.
Audio and Video
* Corrections to RV8 decoder algorithm and MP3/AAC decoder.
* Playing clips without information of number of audio channels improved.
* Streaming quality enhanced.
* Audio routing corrected for Nokia Cark112.
* Pause/resume functionality improved when using Vidiator server.
Browser
* Browser stability improvements.
* Browser behaviour improved when browsing certain pages.
* Language selection for google corrected.
* Pages with background wallpaper now shown correctly.
* WAP email PDP context drop issues solved.
* Resuming after service lost works now correctly.
Messaging
* Stability improvements to IMAP mailbox.
* Mail inbox update is now working correctly.
* Extra line feeds removed from email.
* Notification added when rights object received in inbox.
* SMS sending failure for multiple addresses corrected.
* SMS proactive command interpretation improved.
* Receiving Chinese SMS containing more than 45 characters no longer causes shorter standby time.
* Chinese input added to mailbox user settings.
* Support for Unicode SMS character counter added.
Video Call
* VT call behaviour improved if audio channel is closed and reopened with different bit rate.
* Unmuting audio sending during video call is now possible.
* Overlapping in calling to video mailbox corrected.
* Video sharing stability improved.
* Video Share item added to incall option menu.
* Share video option no longer disappears from option’s menu after 3rd party MT call.
* Video call can now be established correctly with Ericsson VIG.
* THAI language supported now in Snowboard game.
* New error note added if MMC formatting fails.
* Stability improvements for FTP upload.
* Extra security code added to prevent users to play non DRM protected AAC files by renaming the file.
* Correction for USSD channel closing.
* Boot-up ensured even if there is corrupted MMC or corrupted font files in terminal.
* Access point configurator updated.
* Operator name list updated.
* Bluetooth stability with other vendor’s headsets improved.
* Default image resolution changed from Normal to High.
* SyncML client temporary data excluded in backup.
* LifeBlog account registration succeeding.
* Media gallery handles better long play list names and large images.
* Alarm clock volume adjustments.
* Validity check added before setting currency symbol.
* Dialup works now after USB PictBridge printing.
* BT deactivation behaviour with certain headsets improved.
* Folder path name length extended to max. 255 characters.
* All streaming links played correctly from .ram file that contains several streaming links.
* New error note added for out of memory situations.
* Java Install/Notify problem corrected.
* Support for multiple BT connections.
* Serial port signalling handling improved.
