I got an N70 on Orange on Saturday.
I've been annoyed by loads of little things that I've found (no birthdays on calender, lack of stuff that can use the Goto menu & just a rather confusing interface compaired to my old 6230) & I've noticed from this forum that I'm not alone in some of these 😉
However, I've found a rather more annoying bug.
My wallpaper's stuck.
I deleted the file & thought that would fix it, but it didn't, so I downloaded FExplorer & found some of the images I'd had as wallpaper in C:\system\skins\ (all called wallpaper.mbm).
I've also tried removing the battery & memory card, but no joy.
The OS is V 2.0537.1.7
Any ideas how I can fix my wallpaper problem?
SteveA wrote:I got an N70 on Orange on Saturday.
I've been annoyed by loads of little things that I've found (no birthdays on calender, lack of stuff that can use the Goto menu & just a rather confusing interface compaired to my old 6230) & I've noticed from this forum that I'm not alone in some of these 😉However, I've found a rather more annoying bug.
orange firmware??(ornage's 'active' desktop running down the side of the left side of the phone screen??)
steff2632 wrote:orange firmware??(ornage's 'active' desktop running down the side of the left side of the phone screen??)
Yep, it's got that.
The wallpaper used to work- I was quite happily fiddling with different ones, until it got stuck 😞
i think orange disable wallpaper changing unless you get a theme with the wall paper in it
SteveA wrote:Yep, it's got that.The wallpaper used to work- I was quite happily fiddling with different ones, until it got stuck 😞
The filetype that generates the wallpaper is .mbm, so look for that on your c: drive.
