I've forgotten my lock code. How can I get back into my smartphone?
7 replies · 67 views · Started 16 February 2006
Q. I've forgotten my lock code. How can I get back into my smartphone? I've tried hard resetting it to factory conditions, but still it demands my forgotten code!
I am having a similar problem. However the master code generated is not accepted in place of the lock code. I have a Nokia E61i and need to put another SIM in while travelling. I did not bring my USB connection with me so I can not reflash the firmware, and I am in Scotland where there are no Nokia stores (apparently). Do you have any idea why the master code is not working? Or any other suggestions?
If you are looking for your unlock code of the phone then first of all go to service center they will reset your phone so it will able to use in proper way and you do not have to go any repair this phone because it is not other problem its totally west your money.
Hi
I hope you can assist me because i have tried everything i can possibly do.
I have Nokia E65 and i forgot the lock code, i have tried the soft scan code as well as the deep scan code but without any luck.
I have also tried using the Master code which is 0356676170 and my IMEI number is 353263017671576.
Before i can give Nokia more money is there another way for me to reset this for free trying to save the cost.:frown:
