hello fellow phone users,
i bought a nokia N70, and with it came a cable and a cd with nokia pc suite,
i used the program to install a game on the phone, it installed it next to the snowboard game that came with the phone, but when i tried the game it was only half screen, so how can i delete the game, when i press the C button it says"unable to delete" i have not yet used my memory card..
i hope this is clear, i did use the nokia pc suite,
any programs out there that can help me, or any solutions please
THANK YOU
v 3.0546.2.3
18-11-05
rm-84
p.s
how can i remove previous web search's from the phone, like on windows address bar.
u can un-install the game by going to the Manager app in the Tools folder.
Goto Menu -> Tools -> Manager and you will get a list of all the installed softwares on the N70.
Select the game you would like to uninstalled, then go to options and select Remove.
That should do the trick...:icon14:
Peace..
Aadil
Thank You Very Much.
A Big Thank You
for my N70, I noticed, the Manager only allows uninstall of certain apps. some apps do not appear at all in Manager.
E.g. Games like Snake, Card Deck and Snowboard 3D.
Any idea how I can uninstall these?
You can't; they are preinstalled in ROM (Read-Only Memory) on the Z-drive.
Can he not delete them useing FExplorer?
mr g wrote:Can he not delete them useing FExplorer?
No, you cannot edit ROM (Read-Only Memory). Like a CD-ROM.
cavey wrote:No, you cannot edit ROM (Read-Only Memory). Like a CD-ROM.
:redface: oh yeah silly me,were'nt paying too much attention!
