how can install themes in sendo x?
1 replies · 1,694 views · Started 18 February 2006
can somebody help me whit the installation themes, i cant do it, sendo x, new firmware from expansis, what tipe of archives accept?
If I understand you correctly, you'd like to install a theme? In that case you need to get the .sis file on your Sendo X. There are several ways to do this:
1) Via Bluetooth. Make sure your laptop/pc and your X are paired and then just send the file (.sis) Right-click file -> Send To -> BT device
2) Via memorycard. Put the file on your SD/MMC card. Then plug the card in your X and browse to the location via FExplorer, then select the .sis file
3) Via datacable and Sendo pc-connect software. Connect your Sendo to your laptop/pc using the datacable. Click the m-router icon in your sys.tray and tick the box 'cable'. Now your X is connected to your laptop/pc and you're ready to use the pc-connect software to put files on your phone.
When the file is on your X and you selected it, follow the instructions it given. Hope this is clear enough and that it'll work out for you. If these options don't work you could also try IR, but it is very slow compared to the options mentioned above. Let me know if it worked or not. Good luck😊
