plz help me
1 day i put on mi fone to lissen to the songs i put on the 128mb memory card and mi phone is not detecting it. plz help me
is ther a solution without going to a nokia shop
plz can u email it to heyya46@hotmail or if ure too lazy plzzzzzzzzzzz reply to this forums uhhhhhh
regards
nokia 7710 lover
mmc problem!!!
Dude,have you inserted the memory card the right way? Coz if you haven't,then your phone will nt detect it,and moreover ur phone could get damaged this way. So,just check properly whether you have inserted the memory card properly..Still,if it doesn't work,then why dnt you try someone else's memory card?? Otherwise,you'll hv to take ur mobile to a Nokia Care center,no other way out..All The Best
-Cheers
it occured to me a few times, after I removed the card and reinsert it. one time, I have to do it 3-4 times to make the system detect the card. try this: turn off the power, take out the battery, wait 10 seconds, take out the memory card, insert it fully, turn on power. repeat this procedure until it detects it, it will work, itis just the system behaves weird sometime or the contact have some problem.
good luck.
k thnx i got it sorted
i juss had to type my password then it said memory card inserted
i gessed my pass
anyway thnx guys
