Hi
I looked in the forum for information about creating a simple setting list ,
I managed to create one using a dialog ,
but I want to use Options&Back with customized menu instead of Select&Cancel.
1) Can I customize the menu in a dialog ? How?
2) Can you refer me to information about how to implement a setting list box in a view ? what unique methods should be in view&container ?
Thank you very much
