Psiloc please help
8 replies · 2,429 views · Started 20 November 2002
I purchased extended profiles pro and i like it so much
then i installed the task manager
and when i configured it to assign the joystics for shortcuts
i find it not always working
sometimes it work others it doesn't work
is there a special setting i have to do ?
i had the same problem in the demo version,
same for eprofiles app, sometimes it does make the scheduled changes, sometimes not, sometimes there is a different alarmclock sound, sometimes not, and just for one time it also changed the background image when changing the profile..
funny thing about alarm - this happens on a regular basis:
the alarm goess of the 1st time with the default nokia sound,
i just let the phone stay on it's own, so the alrm times out and comes again some minutes later - or i press snooze, no difference.
the 2nd time the alarm goes off - yippie - i get the sound i set in eprofiles... and now... guess what happens 3rd time...? sometimes default nikio sound, sometimes the one set in eprofiles...
sent the guys at psint a message... never got a answer though... so they won't get money from me...
well i also got the full version of eprofiles pro but until now, i haven't got a problem with it!
shadow - which os-version do you have on the phone..? mine is 3.16, maybe there's some sort of incompatibility...?
i think no difference between the full version and the trial
psiloc gave the trail to people to test the program so do u think it puts bugs in it ??
we have to wait for psiloc to give a comment
Hello Didos,
Task Manager waits for message from Phone application (indicates that phone goes to standby) and then wait for joystick movements.
Unfortunately Phone application sometimes does not post that message (probably if phone is busy).
We are working on workaround, please be patient.
Hello Popsmart,
New version of Extended Profiles Pro will be available tomorrow. Main changes:
- much better support for animated phone background
- direct access to standard profile customization, so Extended Profiles can fully replace standard Profile application
- minor bugs fixed
Best regards,
PsiNT
Thanks alot for this quick support
that is what i expect from this great company
can u tell me where can i find a description for each of your application that include a complete describtion of each application how it work and it's features
btw
do i need a new license key to upgrade my purchased version of eprofile pro or i can use my old one ?
psiloc
where u are ?
i was just saying
quick support
is it available yet ???
yes do i need to insert the key again
or just installed the app on top of it ????
i hav problem about he schedule profile
also i hav a question regarding Working days in eprofile and in world clock pro
is these prog share the same working days ???
and sometimes the profile change at 9 o'clock but it doesn;t change to the one i set on 3 o'clock
