How to download midis to 7650?
2 replies · 1,728 views · Started 20 November 2002
Hi all,
I need help with downloading midi files to my nokia 7650 phone. I want download them via Bluetooth from my PC, but I don't know what software to use. I have just Nokia PC suite and I haven't found there any way how to do it. Can anybody help me?
Ok, I have solved it on my own. If someone else is looking for this information, then you can download it with Bemused and delete in recorder (installed in phone)
When you install the driver for your Bluetooth device, they will come with something like My Bluetooth Neighbourhood. It's work like your My Network Neighourhood.
For instance, if you use MSI's transceiving key, you will have installed My Bluetooth Neighbourhood. Double click on "Entire Bluetooth Neighbourhood" and then click on "My Nokia 7650", you will see the "Public Folder". Copy and paste the midi file you have copy on your harddrive and paste inside the "Public Folder". You will recv' a SMS msg once you have paste the file in the folder. Once you open the sms msg, SAVE the midi file. You have just download a midi file in your phone.
Hope this help.
[quote="Biermann"]Hi all,
I need help with downloading midi files to my nokia 7650 phone. I want download them via Bluetooth from my PC, but I don't know what software to use. I have just Nokia PC suite and I haven't found there any way how to do it. Can anybody help me?[/quote]
