So, I remake some themes from nokia to Sendo and have a problem.
ermete3smegisto i wrote you email, but you steel silent. So I ask - may be someone know, how to change text color in theme. I hear something about colors in *.rsc file, but how i can change that color ?
Tux_and_tosh`s font changed so its possible. Can anyone say HOW?
Thx for attention.
Sorry but I'm quite busy at the moment. :banghead:
You are right, you have to modify the rsc file with and hex editor. For example, open the rsc file from tux and tosh and change the colors editing the lines that I have indicated in this file:
http://digilander.libero.it/BullShit/Sendox/rsc_colors.txt
Good luck, it's not an easy operation!
:turtle:
colori sono in esadecimale (gruppi di tre, con uno spazio in mezzo) Color in hexadecimal form (groups of 3 values, with a space between) Inizio riga - Adr.Hex - tema First block of the line - Hex Address - Theme 14 [24,1A,1C] (main selection keys) tasti di selezione principali 28 [2C,2E,30] (menu title) titolo menu 3C [40,42,44] (not selected items in the pop-up) voci non selezionate nel pop-up 50 [54,56,58] (selected item in the pop-up) voce selezionata nel pop-up 64 [68,6A,6C] (not selected items in the second pop-up) voci non selezionate nel sotto-pop-up 78 [7C,7E,80] (selected item in the second pop-up) voce selezionata nel sotto-pop-up 8C [90,92,94] ?? AO [A4,A6,A8] ?? B4 [B8,BA,BC] (menu icon title) scritta icone menu C8 [CC,CE,C0] (not selected item in the menu) voci non selezionate in menu DC [E0,E2,E4] (selected item in the menu and now!) voce selezionata in menu e now! F0 [F4,F6,F8] (selection bar in lists)barra di selezione elenco 104 [108,10A,1C] (not selected item in list) voci non selezionate in elenco 118 [11C,11E,120] (selected item in list) voce selezionata in elenco 12C [130,132,134] (data number in the analog clock) numero data in orologio 140 [144,146,148] (not selected item in now!) voci non selezionate now! 154 [158,15A,15C] (clock) lancette orologio 168 [16C,16E,170] (menu up and down arrows shade) sfumatura frecce 17C [180,182,184] " 190 [194,196,198] " 1A4 [1A8,1AA,1AC] " 1B8 " 1CC " 1E0 " 1F4 " 208 " 21C " 230 " 244 " 258 " 26C " 280 " 294 " 2A8 " 2BC " 2D0 ?? 2E4 [2E8,2EA,2EC] (background box in menu) sfondo casella voce nei menu 2F8 [2FC,2FE,300] (background multi selection menu) sfondo menu selezione multipla 30C [310,312,314] (background screensaver bar) barra screen saver 320 [324,326,328] (text color in screensaver bar) testo screen saver -- INDICATORS COLORS -- 348/35C [358,35A,35C] (background high empty battery) sfondo alto batteria vuota 35c [368,36A,36C] ?? 35c/370 [36E,370,372] (first block battery + background low empty battery) terzo alto tacca batteria + sfondo basso batteria vuota 370 [37E,380,382] ?? 384 [384,386,388] (second block battery) terzo centrale tacca batteria 384/398 [394,396,398] ?? 384 [38A,38C,38E,390,392] ???? 398 [39a,39c,39e] (third block battery) terzo basso tacca batteria 3AC [3B0,3B2,3B4] (indicators main color) colore principale indicatori
Hmm can understand what i must to do, but can u translate italian words ?
if yes i will be really happy. Thx for attention
PS If someone interested i can upload theme, which i making now.
PSS Hmm, i use translator (so nice one ^^) and may be "third block battery - terzo basso tacca batteria" same ? If yes - dont translate ^^
Yes the file is in "dual-language". Italian and English, no differences. Save it and open with notepad.
So i start to change colors and have some questions to you, but its really hard to discuss on the forum = its will be easy to speak in icq.
Can you give me your number ?
my - 978140.
Thx for attention
PS How tou found those colors in rsc? Anyone help you ?
