I don't know which's virus soft running good on 6680, please help me!
Which's virus soft for 6680
A virus soft or an antivirus soft(apps)?
If antivirus, it will be here.
phongit wrote:I don't know which's virus soft running good on 6680, please help me!
Just say no to viruses and anti-virus apps. See http://3lib.ukonline.co.uk/viruses.htm
Steve
slitchfield wrote:Just say no to viruses and anti-virus apps. See http://3lib.ukonline.co.uk/viruses.htmSteve
sorry to say this, but you have stupid logic, then it would be the same for pcs, the article you linked to is also stupid
themafia.69 wrote:sorry to say this, but you have stupid logic, then it would be the same for pcs, the article you linked to is also stupid
No, you're the one who's wrong, there's no such thing as a virus for Symbian OS. Just a bunch of malware utilities that have to be manually accepted in triplicate.
With PCs running Windows, viruses used to be able to install themselves and spread totally silently. How on earth is that the same?
Please have some respect.
Steve Litchfield
no i am not, viruses dont install themselves, they need to be executed, so you are wrong. you could have a virus, on your desktop but as long as it hasnt been executed you cant get infected with it, same on the symbian operating system, it just takes a bit more time than a computer virus to install its self, and dont tell me theres no virus for symbian, because there are many that make phone calls, multimedia msgs and msgs, and also destroy the menu, dont talk when you dont know what ur talking about
themafia.69 wrote:no i am not, viruses dont install themselves, they need to be executed, so you are wrong. you could have a virus, on your desktop but as long as it hasnt been executed you cant get infected with it, same on the symbian operating system, it just takes a bit more time than a computer virus to install its self, and dont tell me theres no virus for symbian, because there are many that make phone calls, multimedia msgs and msgs, and also destroy the menu, dont talk when you dont know what ur talking about
This is my last post on this, because you're completely mistaken. There are hundreds of Windows 'worms' that can install themselves silently, over a TCP/IP port, without any user interaction.
And it's completely IMPOSSIBLE for a Symbian OS application to do the same.
End of thread.
Steve
