Hello everybody, I'm a new 9210 french user.
I've got some little questions
How can i speed up the data transfer ? (except MMC Reader on usb + MMC Card)
Can i unlock the special menu of the phone with the Nokia Original Cable sold with the 9210 ?
And the last but not the least what do you think of MMC 64Mb (or 128 ?) + MP3 Player + HeadPhone. Someone uses his/her 9210 to listen music ? I hope headphone are good.
_________________
<font size=-1>[ This Message was edited by Xavier_OM on 2002-01-20 1300 ]</font>
<font size=-1>[ This Message was edited by Xavier_OM on 2002-01-20 1515 ]</font><font size=-1>[ This Message was edited by Xavier_OM on 2002-01-20 1515 ]</font>
I think (and I could be wrong) that the fastest access you're likely to get with an MMC is with an MMC reader for PC since the 9210 doesn't do USB.
Ok thanks for your answer. So i need a mmc reader. I want to buy a 128Mb card, so does anyone have an idea of where and when i can find it ?
About an other subject, the cable sold with the 9210 can be use as a FBUS cable. Is a MBUS cable necessary to activate NetMonitor Menu or the normal cable using like a FBUS cable will do it ?
_________________
Le temps de passer sa vie � la perdre...<font size=-1>[ This Message was edited by Xavier_OM on 2002-01-20 1515 ]</font>
At the moment 64Mb is the largest available, the 128Mb has been on Immenent Release for a couple of months now with still no sign of it yet. A few site were taking advance orders but that seems to have dissapeared.
In order to activate NetMonitor you will need to get an MBUS cable, once you have activated NetMonitor you can then get rid of your MBUS cable as option 31 in netmonitor will switch the transfer mode of the 9210 - but be warned - if you get your firmware upgraded you will need the cable again to activate netmonitor as I have recently found out and that's why I've just has to purchase my second cable!!!
Thank you for your answer !
