Slow Bluetooth Download rate
4 replies · 2,905 views · Started 25 February 2006
I've got a problem with my 7610, more specifically with the bluetooth....
When I receive any file via bluetooth from other phones, the receive/download rate is around 20KB/s, which is quite slow, compared to the send rate of around 40-50KB/s(when I send files to other phones).
I have tried pairing, using all types of phones (Sony Ericssons, other s60s and Samsungs), but I think the problem is on my side.
I have noticed the same thing with other 7610 phones...
Should I update my firmware, or else is there a patch for this problem.
My firmware version:
V 4.0437.4
15-09-04
RH-51
Note: No antivirus installed.
Kind Regards
Carrot Madman 6
Too many running apps on the background maybe?
Try to run phone with Safe Mode?
Free up C/D drive?
Empty msg?
Change the msg location to MMC?
Format phone & MMC?
Virus?
Nope....
It's the CPU (123Mhz) that's making the Bluetooth slow(compared to other s60 220 Mhz).
Kind Regards
Carrot Madman 6
[FONT="Arial Black"]Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. [/FONT]
the speed of ur blueooth is not really depends on ur phone! its depends on the person wo send the files to u and the person u send ur files to
Person? What do u mean? I don't get it.
AFAIK, BT depends on file size and the range. But I ain't so sure...
