copying contacts to sim
2 replies · 2,297 views · Started 27 February 2006
Wirelessly posted (Nokia3230/2.0 (3.0505.2) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0 UP.Link/6.3.0.0.0)
Yes just go to contacts/options and then select Copy to Sim voila!
It's not actually possible on the Sendo X - the option was removed by Sendo for some reason.
The best bet is to sync. all your contacts to your PC using pcConnect.
