mp3 as ringtone for nokia 6600..its really works!!!!!
45 replies · 138,689 views · Started 01 March 2006
because there were demanding mail to urged me to post the solution here...so i will give u all the solution...check it out....
1. u need the mp3 codec that i will give to u...u have to install the codec on ur phone
2. Important!!!!....the mp3 file must be save in joint stereo 128 bits 44.1Khz...u can make it using the Db power amp converter..if u dont have the converter, email me...i cant post it here because the file is big even in zip format..cant pass the max limit...sorry for the hustle...
3. How's the phone gonna accept the file...😎 ..it simple...the phone will accept the file when it has id3v2 tag....u can set it by using media player like winamp....just import the file to winamp playlist..right click and choose 'view file info'...
4. Now its ready...one more thing...u have to save the mp3 file in the original sound folder on ur memory card...done...
5. Plz give comment and any sugestion...this is my first post...i really hope that i can help u all....
Attachments: Mp3WmaOgg[1].Codec_6600.sis (262 KB)
If it is a real, legitimate solution, why not simply post it here to save the effort of sending email (and for you to reply to them)?
cherr wrote:who ever want their nokia 6600 play mp3 as ringtone instead of the .wav file...dont hesitate to email [email protected] will give u the solution and the software...get rid of all those memory eatin' .wav file...
umm just to let you know the wavs created by the nokia suite was always smaller than the same song in mp3 format at reasonable bitrate, and anyways the 6600 doesnt have stereo speakers so it will sound exactly the same, so really theres no point, unless u make the mp3's really low quality
did it really nokia suite converted wav file i smaller than mp3 file...as far as i know...wav file will always be far cry bigger than mp3 file....any comment mafia.69!!!!
sir
plz tell me this codec which plays mp3 in nokia6600 n set as a ringtone of mp3 file its work or not?? n one thing is also how can we save the mp3 files in gallry coz when we recive mp3 files then try to save it then it always open in mp3 players. so plz if u have any good software which will set mp3 as a ringtone in nokia 6600 then plz send tht file thanx
I have been using mp3 for my ringtone for almost 3 month now..i dont have any prob with it...
for manraivarun,
the codec that i post here will give ur fon to recognise mp3 as one of the sound format...it also recognise .ogg and .wma file...u just have to install the codec...regarding the mp3 file,u can move and save ur mp3 file anywhere u want by using the internal file manager or using 3rd party software like Fexplorer...i guess everyone knows about this...if u had any probs..email me ok manraivarun....
cherr wrote:because there were demanding mail to urged me to post the solution here...so i will give u all the solution...check it out....
Thanks dude for this wonderful act. Actually i was looking for this software for quite some time and found it with u, it works, joint stereo is required. thanx, hope to see more such act of kidness from u. thanx
[CENTER][/CENTER] ihave just found an mp3 plugin but u need first ogg player installed & than the plugin but i have just compiled ogg_player & mp3 plugin together. So every1 try it... Hope u like it...
Download it from here:-
http://www.freewebs.com/saad007/mp3_as_ringtone_6600.sis
NOTE:-
But for mp3 on ringtone u need ID TAG on mp3 first, i have an easy method...
( XP UZERS )
First of all right click on ur mp3 song or tone & click PROPERTIES,
then click on SUMMARY in pop-up window, after it add any thing in TITLE & click OK...
Now it has ID tag & ready 2 used for ringtone in 6600...:icon14:
Enjoy!!!
I hope u like my simple & easy method so plz reply me after try it.....
( [email][email protected][/email] )😎
@Cherr,
thx a lott cherr ... know i can set mp3 as ringtone at 6600
i've undeline this one : u have to save the mp3 file in the original sound folder on ur memory card
the given codec does not or someone have the deatail about how to do this correctly
cherr wrote:did it really nokia suite converted wav file i smaller than mp3 file...as far as i know...wav file will always be far cry bigger than mp3 file....any comment mafia.69!!!!
yes as i told u, its about half the size of an mp3, because its mono, and low bitrate, there is no poing in putting a high bitrate stereo mp3 file which is double the size of the wav if the phone itself has mono speakers, it will sound the same, its a waste of space
i tried ultra mp3 player, mp3 go , ogg player but my nokia 7610 is not able to get digital output, forget about digital is their any software which will help me to get bass output on my nokia 7610.
if you have any such software pls send to me
if you want nay software or carck for mobile pls vist mt web site.
www.dotcomvinod.741.com
thanks
vinod 😊 :icon14:
thank you so much...it is really working
wow it did work... thanks this free chance to somehow upgrade my phone using mp3s... thanks again... by the way do you have an unlock key for Power MP3 Player? hope u have one... thanks!!! more power to you!
:frown:
Is there a bug in the codec
I have installed the codec supplied and followed your instructions
as given.It playes the mp3 only once and then starts playing
the default nokia tone as the ringning tone is there
any way that it ring playing the same mp3 ringtone set at default continously
Regards
keith
man i have been trying to install this probgram for 15 mins
for some reason its not working
always sends me to a odd website
Hey, dude .. i set it as mp3 .. but .. i'm facing some more probs.
i have set an mp3 ringtone ..
but when some 1 calls me .. dat ringtone doesn't play correctly .. u can say looks like dere's an error in it .. !
voice is so disturbed
so,plz help me out .. whts this prob.
I installed it on nokia 6600 and it says at the end of the installation "Sowtware may not be compatible with your phone" and the phone doesn't even see the mp3s in the ringing tone list (profiles-personalize)what should i do??
sivaprasad wrote:thank you so much...it is really working
plz send me the software of set ringing tone in nokia 3660
hello friend i did what u said but but mp3 ringtone is not working in my cell pls help me how it will work..when i play mp3 ringtone it says format not supported
This programe is great :icon14: i have on my phone but i use WMA as ringtones, they sonud better than MP3😎 and for Rahul, there are MP3 that the programe will not play or will play them very slowly my recomendation is, use WMA you can download the programe "Wavepad" to convert the ringtones into WMA good Luck
