would someone help me out
how do you lock the keypad on these phones? since its not a flip phone even with a little touch it dials the number.
thanks :con?
also can you select ring+vibrate togather? it either rings or vibrate
thanks :con?
Press and release the top left button ( Home ) on the lower keypad, then quickly press and release the top right Button ( B game key ) top keys.
Then the same again to unlock.
The phone wont let you unless, you create a ring tone that incorporates the vibrate tone or there is software ,
http://www.allaboutsymbian.com/software/item/Vibor.php
that will let you do it.
Mike
hi thanks for ur help. i locked it now it wont unlock it cuz its asking for the password. i tried the password but its saying incorrect password
what would i have to do to get rid of that password?
If you have not set a password I believe the default is all zeros, 000000.
To disable the password you need to go to the control panel / Password / Phone Lock,
and set Auto phone Lock to OFF.
Mike
hi thanks for ur help mike
it says unlock and then i tried 000000
it didnt work
any other solution
hi never mind i got the password and its working great
thanks
my_galaxy wrote:hi never mind i got the password and its working great
thanks
i got a similar problem with my A920 and l've tried 000000 and 1234 and it still wont unlock. can you help me out??
well someone must ve set up the main password. you have to remove that password.
