problem after problem after problem....HELP
3 replies · 3,191 views · Started 01 March 2006
:frown: hello guys!! can you help me with my 7650:frown: The phone was given to me by my cousin who is in germany. The first problem was everytime i restart my phone a message "system error" occured. Then after a week of using the phone everytime i pull down the keypad, signal was losing but after i return it back signal comes back too.But if the keypad remains pulled down for a minute "insert Sim Card" was displayed. Then after three days, when i started to charged the phone the battery sign is appearing but it's not charging. And if i charge it while the phone is turned on a message "not charging " appeared? Please help....:frown: I tried to go to different service center but other say it's on system, others say it's the flex cable, others says it's dead:con? :con?
By the way, it was a second hand phone used by my cousin and he told me that it's not like that before he gave it to me, He used it for only 2 months
I was wondering if reign found a solution to this problem, as my friend's 7650 is having the same problem with losing the signal completely when the phone is opened.
I have considered getting a new cable for the keypad, in order to resolve the issue, but I can only find one place that sells them, and they're �24 each!!
