In older Nokia like 8210 if you had a birthday note writen in and you turned it back on (ie in morning) it was showing on the screen the birthday note without sound, but at least it reminded you.
Is there a way to do it with nokia 7650?
i haven't really tried or experienced this before but i'm pretty sure it will do the same. 😃
please feel free to correct me if im wrong...
I've tested this. Universary... switched off 7650... next morning turned on... nothing showed.
If you know a solution please inform. thanks in advance
The Calendar program doesn't show things automatically. But, if you set alarm, which you can set alarm time and date, then you will be remind.
what if you put in alarm time and until you turn the mobile back on the alarm time passes?
I tried to simulate it. but I couldn't. I got this experience once. The mobile will remind when you turn it on and tell you that the alarm time is already passed.
