bluetooth to card
5 replies · 1,963 views · Started 03 March 2006
hey.
is there a way i can send my bluetooth recieved files straight to my mem card rather than onto my phone then onto the card?
Also, how do you upgrade the firmware? (on o2 uk, monthly contract)
cheers
rich
Just a note: It's actually called MsvDriveE (note the v). There are a couple renamed copies floating around, but you'd have better chance searching for original name.
If you want the FILES rather than to just save the message you need a program called FORWARD It allows you to search through your messages and save off files to the memory or send them again in other ways. When you find the file you want you just click OPTIONS>COPY FILE and point it where you wish it saved like C: or E: then you can use FExplorer to move it to a sub folder.
Duke.
