Tomtom mem card files
3 replies · 1,595 views · Started 03 March 2006
Can anyone tell me what folders should be on the tomtom mobile MMC?
Like a twit i didnt make a backup of the card before i stuck it in my N70, now i dont know which files are for tomtom & which for the phone and i wanna delete some so that i can put a spain map on there for next week. Not sure if both Spain & GB map will fit on a 256kb card.
Will i be able to backup & delete the GB map and replace it with spain map & use as normal or do i need to have the GB map present too?
I did order a 1gb card from fleabay but the bugger aint arrived yet so i need a contingency plan if it aint here for Tuesday morning.
Cheers
Slim
TomTom folders are:
Great-Britain-Map <or your map name here>
Itn
Licences
Raster
Schemes
TomTom
Voices
Zip
Then, from the "System\Apps" folder...
TTMOBILE
TTNAVCONTACTS
Think thats the lot.
As far as I know you don't need to have the GB map installed - just whichever maps you wish to use.
good question, I need this info aswell because I want to try to put the tomtom files on my 1GB card so I only need one card for everything (tomtom, themes, games, mp3s, ...)
I'm back, it works on my 1 GB card as well but the only problem I have is the fact that I have to open FExplorer and in there I have to start TomTom
The file to start TomTom is ttmobile.app
Do you maybe know where I can place a shortcut in a specific folder to open it without FExplorer.
