6630 vid camera problem
1 replies · 1,636 views · Started 05 March 2006
hello. i have a nokia 6630, and recently i havent been able to use the video camera. if i try to use it, i get a message saying 'feature not supported'. i can still use the normal still camera. i would rather not try and re install everything on the phone, so has anyone got any ideas to the cause of the problem, and how to fix it?
thanks
gazza_dj
gazza_dj wrote:hello. i have a nokia 6630, and recently i havent been able to use the video camera. if i try to use it, i get a message saying 'feature not supported'. i can still use the normal still camera. i would rather not try and re install everything on the phone, so has anyone got any ideas to the cause of the problem, and how to fix it?
thanks
gazza_dj
Well, something that you've installed is messing with the function. Try uninstalling any culprits from Tools | Manager.
Steve Litchfield
