Is this a NEW Bug ???
5 replies · 1,586 views · Started 06 March 2006
I Got a 6630 (V5.03.08) recently its been workin like a charm! But I got this 1 problem😡 when i try to send any .sis file thru FExplorer , File Manager , Fileman ...its givin me a message sayin that "Unable to send Projected Objects":con? . Has anyone got da same problem??:con?
what you can do is rename the file in fexplorer (ex. .sis to .sis2), then send it via bluetooth to your pc. that should do the trick.
asasinationsinc wrote:Thanx:icon14: !!! Renaming worked ! It does send the files to da PC ! Now i gotta try it Phone to Phone!!
cool. just don't forget to rename the file that you transferred to your PC back to its .sis format, and everything else should be cool.
