I have just purchased a Nokia N70 with vodafone but i need to no if i can change were bluetooth applications are installed to.They currently are going into a folder called 'My Own' but i want to change it so they just go onto the menu like on the Nokia 7610.I have tried to delete the folder but it wont let me and i have a program called FExplorer which im sure i can use to resolve this problem.The reason i want to change this is because the folder icon for the theme im using makes it look bad in comparission to the other plus i'd rather have the installs go to the main menu rather than a dedicated folder.
I no that this problem cant be fixed by the phone itself but im sure it can by using the FExplorer software as its solved some other problems ive had.
Hope you can help!
Thanks Mike
